Running a batch
Running a batch
Yes of course.
But in any case I recommend to backup your tasks folder.
This operation is never superfluous.
deesloop
Running a batch
Post by deesloop »
Hmm.
Well I installit and the BAsic module but I'm struggling with the Basic module
It hates my code.
Set objShell = wscript.CreateObject("WScript.Shell")
Not an Object reference
Thats not handy
deesloop
Running a batch
Post by deesloop »
Actually I dopped the wscript. and the error went away
However teh code isn't working
Sub Main
Dim objResult
Dim objfile
Dim dayt
Dim strFolderPath
Set objShell = CreateObject("WScript.Shell")
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set oFolder=CreateObject("scripting.filesystemobject").getfolder ("d:\costs\splits")
On Error Resume Next
For Each aFile In oFolder.Files
    If sNewest = "" Then
        Set fNewest = aFile
        sNewest = aFile.Name
    Else
        If fNewest.DateCreated < aFile.DateCreated Then
             Set fNewest = aFile
        End If
    End If
Next
dayt=(Left(fNewest.Name,10))
Set objfile = objFSO.CreateTextFile("D:\Costs\started.txt")
For lp = 1500 To 2500
objResult = objShell.Run("c:\windows\system32\pdftk.exe d:\costs\splits\????-??-??_" & lp & "*.pdf cat output d:\costs\record\" & dayt & "_" & lp & "_costs.pdf", 1, True)
Next
Set objFolder = objFSO.GetFolder("d:\costs\record")
For Each objfile In objFolder.Files
    contract = Mid(objfile.Name, 12, 4)
    folder = Mid(objfile.Name, 12, 2)
    strFolderPath = "d:\costs\record\" & folder & "00-" & folder & "99\"
If Not objFSO.FolderExists(strFolderPath) Then
        Set objFolder2 = objFSO.CreateFolder(strFolderPath)
End If
    strFolderPath2 = "d:\costs\record\" & folder & "00-" & folder & "99\" & contract & "\"
If Not objFSO.FolderExists(strFolderPath2) Then
        Set objFolder2 = objFSO.CreateFolder(strFolderPath2)
End If
objFSO.MoveFile objfile.Path, strFolderPath2
Next
Set objfile = objFSO.CreateTextFile("D:\Costs\Finished.txt")
Running a batch
Thats not handy
You can make reference manually. See screenshot:
Next choose "Windows Script host object model"
Now you can write code like this:
Sub Main
   Dim o As FileSystemObject
   Set o = New FileSystemObject
   o.GetFolder("c:\temp")
End Sub
It's working.
Running a batch
write this instead:
Set oFolder = objFSO.getfolder("d:\costs\splits")
It's working. I've tested this.
deesloop
Running a batch
Post by deesloop »
Thanks for that
The code runs but doens't do what its supposed to do
It isnt joinging pdfs together.
No errors are thrown up
I've gone thru the code and everything seems to run OK to the point where the code below should run
I'm not getting any feedback from the programme, but when I run the code in the original vbscript it works fine.
Thanks for your assistance thus far though :)
deesloop
Running a batch
Post by deesloop »
OK
I stripped the code back to the pdf join utility only
Sub Main
Dim objResult
Dim lp
objResult = objShell.Run("c:\windows\system32\pdftk.exe d:\costs\splits\????-??-??_" & lp & "*.pdf cat output d:\costs\record\_" & lp & "_costs.pdf", 1, True)
Next
End Sub
It's definitely the pdf join line
I get an error while tracing it
&H8007002 Exception 80070002
Googled it and it says the error suggests cannot find file specified.
now
I know c:\windows\system32\pdftk.exe exists
as does the folder d:\costs\splits and d:\costs\record
Running a batch
It seems the problem is in PDFTK utility.
"cannot find file specified" may mean that system can't find some component of the program too
I tried to run some program from "c:\windows\system32" folder.
It's working without problems in application mode and in service mode too.
see script below:
Sub Main
Dim objResult
Dim s As String
   objResult = objShell.Run("c:\windows\system32\calc.exe", 1, True)
    'RoboTaskApp.WriteToLog(0,CStr(objResult), 0)
End Sub
This script launches CALC.exe. If it is being used in service mode then it launches CALC.EXE in system session.
Running a batch
I've just downloaded PDFTK for Windows and tested this.
This is working in service mode very well.
see script I tested:
Sub Main
Dim objResult
Dim s As String
   objResult = objShell.Run("D:\Temp\pdftk\pdftk.exe D:\incomming\t?.pdf  cat output d:\temp\rt.pdf", 1, True)
End Sub
It concatenated all t?.pdf files into one PDF file without problems
deesloop
Running a batch
Post by deesloop »
OK the problem may be becasue of the loop in the code?
It starts at 1500 and works up
But not every one of these iterations has files that match each month
ONe month there may be 1500, 1501, 1502, 1502, 1504, 1506
Next month there may be 1500, 1502, 1505
File not found may be becasue pdftk can't find that file?
This isn't a problem in the script but could it be aproblem within robotask?
Bombs out on error?
*edit*
Nope thats not it
Did an on errore resume next.
Correct code is being generated but nothing getting done :(
