Split from flat file
trotta
Post by trotta »
I tried 400 the first time. Not sure what is going on but when I change the number I get different results.
For 50 I get 5 blocks
For 400 I get 5 blocks
For 90 I get 90 blocks
For 99 I get 989 blocks
For 10 I get 1 blocks
For 60 I get 6 blocks
For 70 I get 7 blocks
Is it possible to get over 100 blocks?
Is is possible for it to put the remainder in a file also?
I'm sorry, I made mistake.
Look at the step #9 (If then)
It's necessary to compare {numblock} and {maxblock} "As Number" (not "as string"). Fix it please or download corrected example here.
What happened:
if we compare values as strings then
"1" < "400"
"2" < "400"
"3" < "400"
"4" < "400"
BUT
"5" > "400"
because strings are being compared in alphabetical order (not as numeric values)
The remainder will be written in last "SMALL" file in any case.
trotta
Post by trotta »
It is working pretty well.  But when I try to split large files, over 20,000 KB or over 800 blocks it will split the first four then does not produce an additional file after that.  I'm looking to split a file of over 80,000 blocks into smaller files of 2,000 blocks.
Step #20 (Create text file ) of the example always writes the remainder of the text into file. It is placed after the loop and writes last blocks.
Pack your large file into ZIP or RAR or 7Z and send to me to oleg(at)robotask.com
I want to test it myself
It works correctly with my test examples. I need to test it on real file.
I made the test on file 38Mbyte (1 833 721 lines)
I tried to split this file to small files 800 blocks per file.
The task created 350 small files correctly and wrote the remainder into file #350.
Maybe the problem in your file. Probably there are some nuances which algorithm doesn't take into consideration.
trotta
Post by trotta »
We were able to get this working well and now have another challenge.
We need to split the file the same as before but now use the number of lines or the split file size in KB in addition to splitting after a 5.
To count number of lines you can use line counter in the text loop. Counter is a simple variable that increases by 1 at each iteration of
the loop.
To calculate the size of part-file use system variable {StrLength({PARTTEXT})}
This variable calculates the length of variable PARTTEXT in bytes
Full list of system variables here.
trotta
Post by trotta »
It needs to split on line 2,500 if the first number of the line is 5. If it is not 5 it goes to the next line.
If the next line is  5, then it splits, if not then it needs to go to the next line and repeat until it gets to a line that starts with 5.
Then continues counting lines until line number 5,000 and split again if the first number of the line is 5.
If the next line is 5, then it splits if not then it needs to go to the next line and repeat until it gets to a line that starts with 5.
The line splits are at 2,500, 5,000, 7,500, 10,000, 12,500 and so on until the end of the file.
See the example below.
You can change the name of source file and number of lines of each part at steps #1 and #2
CatID=INTEGER|2099193306
ExternalName=STRING|"Task14"
ID=INTEGER|509484789
Name=STRING|"Split by number of lines"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Name=STRING|"Create local variable ""SOURCEFILE"" with value ""D:\Temp\txt\big.txt"""
varname=STRING|"SOURCEFILE"
varvalue=STRING|"D:\Temp\txt\big.txt"
Name=STRING|"Set variable ""TEXT"" with value ""{text}{cline}{EOL}"""
varname=STRING|"TEXT"
varvalue=STRING|"{text}{cline}{EOL}"
Name=STRING|"//If more then MAXLINES"
comment=STRING|"If more then MAXLINES"
[Actions\Action12\Params]
operator=STRING|"2"
type=STRING|"1"
value1=STRING|"{cnt}"
value2=STRING|"{maxlines}"
Name=STRING|"STR Extract"
[Actions\Action13\Params]
amount=STRING|"1"
from=STRING|"1"
source=STRING|"{cline}"
variable=STRING|"FirstChar"
[Actions\Action14]
Name=STRING|"//If found 5"
[Actions\Action14\Params]
comment=STRING|"If found 5"
[Actions\Action15]
[Actions\Action15\Params]
value1=STRING|"{FirstChar}"
value2=STRING|"5"
[Actions\Action16]
Name=STRING|"Create text file {sourcefile}.{numfile}"
[Actions\Action16\Params]
fileexists=STRING|"0"
filname=STRING|"{sourcefile}.{numfile}"
line0=STRING|"{text}"
suppress=STRING|"1"
[Actions\Action17]
Name=STRING|"Increment variable ""numfile"""
[Actions\Action17\Params]
incement=STRING|"1"
vaiable=STRING|"numfile"
[Actions\Action18]
Name=STRING|"Create local variable ""TEXT"" with value """""
[Actions\Action18\Params]
[Actions\Action19]
Name=STRING|"Create local variable ""CNT"" with value ""0"""
[Actions\Action19\Params]
varname=STRING|"CNT"
varvalue=STRING|"0"
Name=STRING|"Create local variable ""MAXLINES"" with value ""2500"""
varname=STRING|"MAXLINES"
varvalue=STRING|"2500"
[Actions\Action20]
[Actions\Action21]
[Actions\Action22]
[Actions\Action23]
Name=STRING|"//Write reminder"
[Actions\Action23\Params]
comment=STRING|"Write reminder"
[Actions\Action24]
[Actions\Action24\Params]
suppress=STRING|"1"
varvalue=STRING|"0"
Name=STRING|"Create local variable ""CLINE"" with value """""
varname=STRING|"CLINE"
Name=STRING|"Create local variable ""FIRSTCHAR"" with value """""
varname=STRING|"FIRSTCHAR"
Name=STRING|"Create local variable ""NUMFILE"" with value ""1"""
varname=STRING|"NUMFILE"
varvalue=STRING|"1"
Name=STRING|"Text Loop"
destvar=STRING|"CLINE"
file=STRING|"{sourcefile}"
linecount=STRING|"0"
sourcetext=STRING|"0"
Name=STRING|"Increment variable ""cnt"""
incement=STRING|"1"
vaiable=STRING|"cnt"
