Error during processing actions
John Long
Post by John Long »
I: 9/23/2004
11:04:00 AM: ****** Starting task...
I: 9/23/2004
11:04:00 AM: Task started with
priority: Normal
I: 9/23/2004
11:04:00 AM: Executing "Stop service "MarsDB""
I: 9/23/2004
11:04:00 AM: Executing "Delay 30000 ms"
I: 9/23/2004
11:04:30 AM: Executing "Remove Nonempty Folder  (D:\MARS\netdata2_old)"
I: 9/23/2004
11:04:30 AM: Executing "If
Then"
I: 9/23/2004
11:04:30 AM: Executing "Remove Nonempty Folder  (D:\MARS\netdata_old)"
I: 9/23/2004
11:04:30 AM: Executing "If Then"
I: 9/23/2004
11:04:30 AM: Executing "Rename Folder "D:\MARS\NetData""
I: 9/23/2004
Then"
I: 9/23/2004
11:04:30 AM: Executing "Rename Folder "D:\MARS\NetData2""
I: 9/23/2004
11:04:31 AM: Executing "If
Then"
I: 9/23/2004
11:04:31 AM: Executing "Create Folder (D:\MARS\NetData)"
I: 9/23/2004
11:04:31 AM: Executing "Create Folder (D:\MARS\NetData2)"
I: 9/23/2004
11:04:31 AM: Executing "Copy/Move File"
I: 9/23/2004
W: 9/23/2004
11:04:31 AM: An error occured. Can't copy file:
D:\Backup\MARS\temp_nd\marswsql.db
W: 9/23/2004
11:04:31 AM: The operation completed successfully.
W: 9/23/2004
D:\Backup\MARS\temp_nd\marswsql.log
W: 9/23/2004
E: 9/23/2004
11:04:31 AM: An error occured. Step #29 (Copy/Move File).
I: 9/23/2004
W: 9/23/2004
D:\Backup\MARS\temp_nd2\marswsql.db
W: 9/23/2004
W: 9/23/2004
D:\Backup\MARS\temp_nd2\marswsql.log
W: 9/23/2004
E: 9/23/2004
11:04:31 AM: An error occured. Step #30 (Copy/Move File).
I: 9/23/2004
W: 9/23/2004
11:04:31 AM: An error occured. Can't copy file: D:\Backup\backup\backup_log.txt
W: 9/23/2004
E: 9/23/2004
11:04:31 AM: An error occured. Step #31 (Copy/Move File).
I: 9/23/2004
11:04:31 AM: Executing "Remove Empty Folder (D:\Backup\backup)"
E: 9/23/2004
11:04:31 AM: The system cannot find the file specified.
E: 9/23/2004
11:04:31 AM: An error occured. Step #32 (Remove Empty Folder
(D:\Backup\backup)).
I: 9/23/2004
11:04:31 AM: Executing "Remove Empty Folder (D:\Backup\MARS)"
E: 9/23/2004
E: 9/23/2004
11:04:31 AM: An error occured. Step #33 (Remove Empty Folder (D:\Backup\MARS)).
I: 9/23/2004
11:04:31 AM: Executing "Start service "MarsDB""
I: 9/23/2004
11:04:31 AM: Task executed successfully
I: 9/23/2004 11:04:00 AM: ****** Starting task... ******************
I: 9/23/2004 11:04:00 AM: Task started with priority: Normal
I: 9/23/2004 11:04:00 AM: Executing "Stop service "MarsDB""
I: 9/23/2004 11:04:00 AM: Executing "Delay 30000 ms"
I: 9/23/2004 11:04:30 AM: Executing "Remove Nonempty Folder (D:\MARS\netdata2_old)"
I: 9/23/2004 11:04:30 AM: Executing "If Then"
I: 9/23/2004 11:04:30 AM: Executing "Remove Nonempty Folder (D:\MARS\netdata_old)"
I: 9/23/2004 11:04:30 AM: Executing "Rename Folder "D:\MARS\NetData""
I: 9/23/2004 11:04:30 AM: Executing "Rename Folder "D:\MARS\NetData2""
I: 9/23/2004 11:04:31 AM: Executing "If Then"
I: 9/23/2004 11:04:31 AM: Executing "Create Folder (D:\MARS\NetData)"
I: 9/23/2004 11:04:31 AM: Executing "Create Folder (D:\MARS\NetData2)"
I: 9/23/2004 11:04:31 AM: Executing "Copy/Move File"
You have no errors at this block, therefore you not got any email messages. I think you checked errors here after "Remove Nonempty Folder" and "Rename Folder" operations
W: 9/23/2004 11:04:31 AM: An error occured. Can't copy file: D:\Backup\MARS\temp_nd\marswsql.db
W: 9/23/2004 11:04:31 AM: The operation completed successfully.
W: 9/23/2004 11:04:31 AM: An error occured. Can't copy file: D:\Backup\MARS\temp_nd\marswsql.log
E: 9/23/2004 11:04:31 AM: An error occured. Step #29 (Copy/Move File).
W: 9/23/2004 11:04:31 AM: An error occured. Can't copy file: D:\Backup\MARS\temp_nd2\marswsql.db
W: 9/23/2004 11:04:31 AM: An error occured. Can't copy file: D:\Backup\MARS\temp_nd2\marswsql.log
E: 9/23/2004 11:04:31 AM: An error occured. Step #30 (Copy/Move File).
W: 9/23/2004 11:04:31 AM: An error occured. Can't copy file: D:\Backup\backup\backup_log.txt
E: 9/23/2004 11:04:31 AM: An error occured. Step #31 (Copy/Move File).
I: 9/23/2004 11:04:31 AM: Executing "Remove Empty Folder (D:\Backup\backup)"
E: 9/23/2004 11:04:31 AM: The system cannot find the file specified.
E: 9/23/2004 11:04:31 AM: An error occured. Step #32 (Remove Empty Folder (D:\Backup\backup)).
I: 9/23/2004 11:04:31 AM: Executing "Remove Empty Folder (D:\Backup\MARS)"
E: 9/23/2004 11:04:31 AM: An error occured. Step #33 (Remove Empty Folder (D:\Backup\MARS)).
I: 9/23/2004 11:04:31 AM: Executing "Start service "MarsDB""
I: 9/23/2004 11:04:31 AM: Task executed successfully
Some errors was occured at this block, but you did not check any errors here.
John Long
Post by John Long »
You are correct. The best thing for me to do is to write it down first
then put the plan into action. Sometimes you have to slow down. It is
easy to loose track of some of the steeps in a task this big. Plus I
have never done anything like this and I am trying to rush to the end
result. Thanks for all of the help.
