Hi Oleg,
I have a question:
if I make a "file.Bat",with this text:
net use y: \\sshfs.r\blabla@215.107.108.156!22/var/www /persistent:Yes
And I'll click on the "file.bat" the drivemap will work perfectly.
If I try to use this "file.bat" in robotask it doesn't work.
I've tried both 'run program' or 'run command line utility'
Can you explain to me what I'm doing wrong?
Thank you!
Re: run command line utility
Try something like this, working on my bat file
net use L: "\\SRVJAEDC02\Redaccion\Edicion DIA\PORTADA PARA WEB"
