Should be simple. Right?
56Loaches
Post by 56Loaches »
I want to "GoTo" my C:/ drive...or any other.
I want to go to a specific folder on any of my drives.
What is the "Action" ?
Kevin
Re: Should be simple. Right?
You can use Run program/Open documentaction and specify necessary folder.
Look at my example below. It opens c:\temp folder
ExternalName=STRING|"Task221"
ID=INTEGER|-386182928
Name=STRING|"Open temp folder"
Name=STRING|"Run ""temp """
ifnonzero=STRING|"0"
program=STRING|"c:\temp"
runas=STRING|"0"
wait=STRING|"0"
56Loaches
Post by 56Loaches »
Oleg,
The instructions in your first sentence were enough. I hadn't continued through to see how many variables there were with each action choice.
Thanks very much.
Kevin
