reading logs
Mr_Yaro
reading logs
Post by Mr_Yaro »
Hello everyone,
I have a log file that is being updated everyday. does anyone know how to check if specific string is present in that txt file?
thanks
Re: reading logs
Look at the task below.
CatID=INTEGER|1181470169
ExternalName=STRING|"Task197"
ID=INTEGER|-887441753
Name=STRING|"Check string in the text file"
Name=STRING|"Set variable ""FILENAME"" with value ""C:\incoming\test.txt"""
varname=STRING|"FILENAME"
varvalue=STRING|"C:\incoming\test.txt"
Name=STRING|"Set variable ""SUBSTRING"" with value ""Hello world"""
varname=STRING|"SUBSTRING"
varvalue=STRING|"Hello world"
operator=STRING|"6"
value1=STRING|"{Substring}"
value2=STRING|"{TextFile({FileName})}"
Name=STRING|"Show ""File ""{filename}"" contains the string ""{SubString}"""""
msg0=STRING|"File ""{filename}"" contains the string ""{SubString}"""
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""File ""{filename}"" doesn't contain the string ""{SubString}"""""
icon=STRING|"3"
msg0=STRING|"File ""{filename}"" doesn't contain the string ""{SubString}"""
