Check email for subject line if match -> Print Email
ryan
Post by ryan »
I am looking to have robotask check my gmail and if the subject line contains "something is broke" to print that email on my local printer.
Any help on this would be much appreciated!!
Thanks!
ryan
Re: Check email for subject line if match -> Print Email
Post by ryan »
You can download necessary message to EML file and print the message body
Look at this example:
ExternalName=STRING|"Task629"
ID=INTEGER|299352747
Name=STRING|"Print eml body"
ActionID=STRING|"A_EMAILE_PARSE"
Name=STRING|"Parse Email Message"
cc=STRING|"0"
date=STRING|"0"
extract=STRING|"0"
file=STRING|"D:\robot_spam\20120726143214975.eml"
from=STRING|"0"
overwrite=STRING|"0"
priority=STRING|"0"
savefilenames=STRING|"0"
subj=STRING|"0"
text=STRING|"1"
texttype=STRING|"0"
textvar=STRING|"txt"
to=STRING|"0"
Name=STRING|"Create text file D:\robot_spam\body.txt"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"D:\robot_spam\body.txt"
line0=STRING|"{txt}"
suppress=STRING|"0"
ActionID=STRING|"A_GENERAL_PRINTDOC"
Name=STRING|"Print body.txt"
files=STRING|"D:\robot_spam\body.txt"
infinite=STRING|"0"
printer=STRING|"CutePDF Writer"
printto=STRING|"0"
timeout=STRING|"60"
wait=STRING|"0"
2-nd way
You can print whole EML file. Jist save it as TXT file and print it.
An EML file is a simple text file, but it has a special format. But you can work with it as a text file.
