Import XML or CSV to SQL
Postby deesloop » Tue Jun 05, 2018 12:19 pm
Basically I get a CSV file sent in via ftp - basically 2 rows (A header and the data)
It's named as Audited-DOCREF or Closed-DOCREF
What I want to do it update SQL database record DOCREF with the data
So it logs into sql and does a count of records number DOCREF
If it find them then it deletes that recor
It should then add the contents of row 2 frm the CSV into the database
This would either create new records or replace existing.
I have tried using bulk insert
BULK INSERT mcls015
FROM {FILELIST}
GO
But that doesn't work.
How can I read a CSV file and pus it into SQL?
The field order of the excel file will match the database.
Thanks
deesloop
Re: Import XML or CSV to SQL
Postby Oleg » Tue Jun 05, 2018 5:20 pm
SQL syntax depends on your database.
I think that you should use standard algorithm and add row-by-row
SQL like this:
insert into <tbl_name>
(col_name1 , col_name2,  ... col_nameN)
values (value1, value2, ... valueN)
The algorithm of the task like this:
text loop // on your CSV file
    SQL Query // with SQL above
end loop
Postby deesloop » Thu Jun 07, 2018 9:14 am
Yes that's exactly what I'm looking at. Thanks.
However I've an issue saying that the file cannot be opened when trying to extract the values for ASQL upload
The file does exists and the filename assigned to filelist seems to match.
That variable is then used later to delete the CSV file so it can't be that.
Error is
E: 07/06/2018 09:44:12: Cannot open file "C:\FTPInkwrx\MCLS015\Audited-6300595.csv
E: 07/06/2018 09:44:12: ". The filename, directory name, or volume label syntax is incorrect
CatID=INTEGER|0
ExternalName=STRING|"Task19"
ID=INTEGER|2102834449
Name=STRING|"MCLS015"
ActionID=STRING|"A_DB_OPEN"
Name=STRING|"DB Open"
connectionstring=STRING|"Provider=SQLOLEDB.1;Persist Security Info=False;User ID=sa;Initial Catalog=TabletForms;Data Source=SQLBOX"
override=STRING|"1"
password=STRING|"2801316022272863579116858"
userid=STRING|"RecordsAdmin"
ActionID=STRING|"A_DB_CLOSE"
Name=STRING|"DB Close"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{FILELIST}"
hidden=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
ToRecycleBin=STRING|"0"
Name=STRING|"Get Document ID"
amount=STRING|"7"
from=STRING|"29"
source=STRING|"{FILELIST}"
variable=STRING|"DOCID"
ActionID=STRING|"A_DB_EXECSQL"
Name=STRING|"Check database for existing"
assignvar=STRING|"1"
paramcount=STRING|"0"
sql=STRING|"""SELECT [DocRef]"",""  FROM [TabletForms].[dbo].[MCLS015]"",""  where docref={DOCID}"""
timeout=STRING|"60"
varname=STRING|"EXISTS"
Name=STRING|"If record exists"
operator=STRING|"1"
value1=STRING|"EXISTS"
value2=STRING|"0"
Name=STRING|"Delete record"
assignvar=STRING|"0"
sql=STRING|"""DELETE FROM [TabletForms].[dbo].[MCLS015]"",""where docref={DOCID};"""
timeout=STRING|"60"
Name=STRING|"Open CSV"
destvar=STRING|"LINE"
file=STRING|"{FILELIST}"
linecount=STRING|"0"
sourcetext=STRING|"0"
Name=STRING|"Insert in SQL"
sql=STRING|"""INSERT INTO TabletForms].[dbo].[MCLS015]"","" [DocRef]"",""      ,[ContractID]"",""      ,[ContractName]"",""      ,[Location]"",""      ,[AuditDate]"",""      ,[AuditTime]"",""      ,[Auditor1]"",""      ,[AuditPosition1]"",""      ,[Auditor2]"",""      ,[AuditPosition2]"",""      ,[Status]"",""      ,[AuditComment01]"",""      ,[ToAction01]"",""      ,[CloseComment01]"",""      ,[AuditComment02]"",""      ,[ToAction02]"",""      ,[CloseComment02]"",""      ,[AuditComment03]"",""      ,[ToAction03]"",""      ,[CloseComment03]"",""      ,[AuditComment04]"",""      ,[ToAction04]"",""      ,[CloseComment04]"",""      ,[AuditComment05]"",""      ,[ToAction05]"",""      ,[CloseComment05]"",""      ,[AuditComment06]"",""      ,[ToAction06]"",""      ,[CloseComment06]"",""      ,[AuditComment07]"",""      ,[ToAction07]"",""      ,[CloseComment07]"",""      ,[AuditComment08]"",""      ,[ToAction08]"",""      ,[CloseComment08]"",""      ,[AuditComment09]"",""      ,[ToAction09]"",""      ,[CloseComment09]"",""      ,[AuditComment10]"",""      ,[ToAction10]"",""      ,[CloseComment10]"",""      ,[AuditComment11]"",""      ,[ToAction11]"",""      ,[CloseComment11]"",""      ,[AuditComment12]"",""      ,[ToAction12]"",""      ,[CloseComment12]"",""      ,[AuditComment13]"",""      ,[ToAction13]"",""      ,[CloseComment13]"",""      ,[AuditComment14]"",""      ,[ToAction14]"",""      ,[CloseComment14]"",""      ,[AuditComment15]"",""      ,[ToAction15]"",""      ,[CloseComment15]"",""      ,[AuditComment16]"",""      ,[ToAction16]"",""      ,[CloseComment16]"",""      ,[AuditComment17]"",""      ,[ToAction17]"",""      ,[CloseComment17]"",""      ,[AuditComment18]"",""      ,[ToAction18]"",""      ,[CloseComment18]"",""      ,[AuditComment19]"",""      ,[ToAction19]"",""      ,[CloseComment19]"",""      ,[AuditComment20]"",""      ,[ToAction20]"",""      ,[CloseComment20]"",""      ,[AuditComment21]"",""      ,[ToAction21]"",""      ,[CloseComment21]"",""      ,[AuditComment22]"",""      ,[ToAction22]"",""      ,[CloseComment22]"",""      ,[AuditComment23]"",""      ,[ToAction23]"",""      ,[CloseComment23]"",""      ,[AuditComment24]"",""      ,[ToAction24]"",""      ,[CloseComment24]"",""      ,[AuditComment25]"",""      ,[ToAction25]"",""      ,[CloseComment25]"",""      ,[AuditComment26]"",""      ,[ToAction26]"",""      ,[CloseComment26]"",""      ,[AuditComment27]"",""      ,[ToAction27]"",""      ,[CloseComment27]"",""      ,[AuditComment28]"",""      ,[ToAction28]"",""      ,[CloseComment28]"",""      ,[TobeReviewedBy]"",""      ,[AuditorSignature]"",""      ,[AgentSignature]"",,""VALUES "",""('{Line(0)}','{Line(1)}','{Line(2)}','{Line(3)}','{Line(4)}','{Line(5)}','{Line(6)}','{Line(7)}','{Line(8)}','{Line(9)}','{Line(10)}','{Line(11)}','{Line(12)}','{Line(13)}','{Line(14)}','{Line(15)}','{Line(16)}','{Line(17)}','{Line(18)}','{Line(19)}','{Line(20)}','{Line(21)}','{Line(22)}','{Line(23)}','{Line(24)}','{Line(25)}','{Line(26)}','{Line(27)}','{Line(28)}','{Line(29)}','{Line(30)}','{Line(31)}','{Line(32)}','{Line(33)}','{Line(34)}','{Line(35)}','{Line(36)}','{Line(37)}','{Line(38)}','{Line(39)}','{Line(40)}','{Line(41)}','{Line(42)}','{Line(43)}','{Line(44)}','{Line(45)}','{Line(46)}','{Line(47)}','{Line(48)}','{Line(49)}','{Line(50)}','{Line(51)}','{Line(52)}','{Line(53)}','{Line(54)}','{Line(55)}','{Line(56)}','{Line(57)}','{Line(58)}','{Line(59)}','{Line(60)}','{Line(61)}','{Line(62)}','{Line(63)}','{Line(64)}','{Line(65)}','{Line(66)}','{Line(67)}','{Line(68)}','{Line(69)}','{Line(70)}','{Line(71)}','{Line(72)}','{Line(73)}','{Line(74)}','{Line(75)}','{Line(76)}','{Line(77)}','{Line(78)}','{Line"",""(79)}','{Line(80)}','{Line(81)}','{Line(82)}','{Line(83)}','{Line(84)}','{Line(85)}','{Line(86)}','{Line(87)}','{Line(88)}','{Line(89)}','{Line(90)}','{Line(91)}','{Line(92)}','{Line(93)}','{Line(94)}','{Line(95)}','{Line(96)}','{Line(97)}',)"","
timeout=STRING|"60"
Name=STRING|"Close CSV"
UniqueID=INTEGER|-918216666
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
folder1=STRING|"C:\FTPInkwrx\MCLS015"
foldercount=STRING|"1"
incmask=STRING|"*.csv"
interval=STRING|"5"
listmode=STRING|"2"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
newlistparameter=STRING|"FILELIST"
pass=STRING|"1"
passmode=STRING|"2"
required=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"0"
deesloop
Postby Oleg » Thu Jun 07, 2018 11:27 am
Hm-m-m...
1. Step #3. SQL query SELECT you should use DB Loop
some databases returns always 0 as Affected rows for Select query
2. Variable (parameter) FileList contains the list of files as text: one file name per line. File monitor returns the list of files. No matter one file or many.
This text contains at least one END-OF-LINE combination. So you have to use Text Loop action to process this file
I think that this is the cause.
Postby deesloop » Thu Jun 07, 2018 11:52 am
OK, Point 1 I'll look at later
Point 2.
I've added a textloop to process as a filelist
Each entry in file list should be assigned to CSVfile vairable
It seems to work but I'm having issues converting the csv file to date & time usage.Getting closer though ;)
deesloop
Postby Oleg » Thu Jun 07, 2018 12:54 pm
... but I'm having issues converting the csv file to date & time....
It depends on you database kind, your system date-time format and your CSV file.
I recommend you to use parameters in your SQL. There are many problems with date-time values if you use SQL text explicitly.
Postby deesloop » Thu Jun 07, 2018 1:19 pm
I'm in discussions with the 3rd party that produces the CSV
Interestingly I've asked for date format to always be yyyy-mm-dd but I'm getting it as dd-mm-yy
I've manually edited the CSV to get yyyy-mm-dd but I'll have a look at using date function of robotask
*Edit*
Actually I'm not getting far with it.
I had thought I could use DateTimeToFormat({Date},yyyy-mm-dd)} where the date was Line(4) from the csv file
*Edit2*
Also tried using SQL todate function - TO_DATE({Line(4)}, 'YYYY/MM/DD') but that's not working either.
Used a text windows to show contents of LINE(4) - this I thought to be the 5th item I nthe CSV file.
As it's a CSV file I had thought that LINE(0) was the first field, LINE(1) was second etc
But it appears that spaces cause issues I nCSV file - is that the case?
Does reading a text file (even if its csv) make each word (separated by a space) a field in an array?
MY CSV file contains a lot of field that require users to enter a short description.
If this is the case how do I use only commas to delineate each field?
Thanks for your pateince
CatID=INTEGER|0
Action14=FOLDER
Action15=FOLDER
Name=STRING|"File Loop"
date1=STRING|"20180607"
date2=STRING|"20180607"
destvar=STRING|"FILELIST"
DuringMinutes=STRING|"1"
file0=STRING|"C:\FTPInkwrx\MCLS015\*.csv"
searchkind=STRING|"0"
sort=STRING|"1"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Create local variable ""AUDITDATE"" with value ""{DateTimeToFormat({LINE(4)},yyyy-mm-dd)}"""
varname=STRING|"AUDITDATE"
varvalue=STRING|"{DateTimeToFormat({LINE(4)},yyyy-mm-dd)}"
sql=STRING|"""INSERT INTO [TabletForms].[dbo].[MCLS015]"",""( [DocRef]"",""      ,[ContractID]"",""      ,[ContractName]"",""      ,[Location]"",""      ,[AuditDate]"",""      ,[AuditTime]"",""      ,[Auditor1]"",""      ,[AuditorPosition1]"",""      ,[Auditor2]"",""      ,[AuditorPosition2]"",""      ,[Status]"",""      ,[AuditComment01]"",""      ,[ToAction01]"",""      ,[CloseComment01]"",""      ,[AuditComment02]"",""      ,[ToAction02]"",""      ,[CloseComment02]"",""      ,[AuditComment03]"",""      ,[ToAction03]"",""      ,[CloseComment03]"",""      ,[AuditComment04]"",""      ,[ToAction04]"",""      ,[CloseComment04]"",""      ,[AuditComment05]"",""      ,[ToAction05]"",""      ,[CloseComment05]"",""      ,[AuditComment06]"",""      ,[ToAction06]"",""      ,[CloseComment06]"",""      ,[AuditComment07]"",""      ,[ToAction07]"",""      ,[CloseComment07]"",""      ,[AuditComment08]"",""      ,[ToAction08]"",""      ,[CloseComment08]"",""      ,[AuditComment09]"",""      ,[ToAction09]"",""      ,[CloseComment09]"",""      ,[AuditComment10]"",""      ,[ToAction10]"",""      ,[CloseComment10]"",""      ,[AuditComment11]"",""      ,[ToAction11]"",""      ,[CloseComment11]"",""      ,[AuditComment12]"",""      ,[ToAction12]"",""      ,[CloseComment12]"",""      ,[AuditComment13]"",""      ,[ToAction13]"",""      ,[CloseComment13]"",""      ,[AuditComment14]"",""      ,[ToAction14]"",""      ,[CloseComment14]"",""      ,[AuditComment15]"",""      ,[ToAction15]"",""      ,[CloseComment15]"",""      ,[AuditComment16]"",""      ,[ToAction16]"",""      ,[CloseComment16]"",""      ,[AuditComment17]"",""      ,[ToAction17]"",""      ,[CloseComment17]"",""      ,[AuditComment18]"",""      ,[ToAction18]"",""      ,[CloseComment18]"",""      ,[AuditComment19]"",""      ,[ToAction19]"",""      ,[CloseComment19]"",""      ,[AuditComment20]"",""      ,[ToAction20]"",""      ,[CloseComment20]"",""      ,[AuditComment21]"",""      ,[ToAction21]"",""      ,[CloseComment21]"",""      ,[AuditComment22]"",""      ,[ToAction22]"",""      ,[CloseComment22]"",""      ,[AuditComment23]"",""      ,[ToAction23]"",""      ,[CloseComment23]"",""      ,[AuditComment24]"",""      ,[ToAction24]"",""      ,[CloseComment24]"",""      ,[AuditComment25]"",""      ,[ToAction25]"",""      ,[CloseComment25]"",""      ,[AuditComment26]"",""      ,[ToAction26]"",""      ,[CloseComment26]"",""      ,[AuditComment27]"",""      ,[ToAction27]"",""      ,[CloseComment27]"",""      ,[AuditComment28]"",""      ,[ToAction28]"",""      ,[CloseComment28]"",""      ,[TobeReviewedBy]"",""      ,[AuditorSignature]"",""      ,[AgentSignature])"",,""VALUES "",""('{Line(0)}','{Line(1)}','{Line(2)}','{Line(3)}', TO_DATE({Line(4)}, 'YYYY/MM/DD'),'{Line(5)}','{Line(6)}','{Line(7)}','{Line(8)}','{Line(9)}','{Line(10)}','{Line(11)}','{Line(12)}','{Line(13)}','{Line(14)}','{Line(15)}','{Line(16)}','{Line(17)}','{Line(18)}','{Line(19)}','{Line(20)}','{Line(21)}','{Line(22)}','{Line(23)}','{Line(24)}','{Line(25)}','{Line(26)}','{Line(27)}','{Line(28)}','{Line(29)}','{Line(30)}','{Line(31)}','{Line(32)}','{Line(33)}','{Line(34)}','{Line(35)}','{Line(36)}','{Line(37)}','{Line(38)}','{Line(39)}','{Line(40)}','{Line(41)}','{Line(42)}','{Line(43)}','{Line(44)}','{Line(45)}','{Line(46)}','{Line(47)}','{Line(48)}','{Line(49)}','{Line(50)}','{Line(51)}','{Line(52)}','{Line(53)}','{Line(54)}','{Line(55)}','{Line(56)}','{Line(57)}','{Line(58)}','{Line(59)}','{Line(60)}','{Line(61)}','{Line(62)}','{Line(63)}','{Line(64)}','{Line(65)}','{Line(66)}','{Line(67)}','{Line(68)}','{Line(69)}','{Line(70)}','{Line(71)}','{Line(72)}','{Line(73)}','{Line(74)}','{Line(75)}','{Line(76)}','{Line(77)"",""}','{Line(78)}','{Line(79)}','{Line(80)}','{Line(81)}','{Line(82)}','{Line(83)}','{Line(84)}','{Line(85)}','{Line(86)}','{Line(87)}','{Line(88)}','{Line(89)}','{Line(90)}','{Line(91)}','{Line(92)}','{Line(93)}','{Line(94)}','{Line(95)}','{Line(96)}','{Line(97)}')"""
timeout=STRING|"60"
[Actions\Action14]
[Actions\Action14\Params]
Count=STRING|"1"
hidden=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
[Actions\Action15]
override=STRING|"1"
password=STRING|"2801516022272863579116858"
userid=STRING|"RECORDSADMIN"
amount=STRING|"7"
from=STRING|"29"
ActionID=STRING|"A_DB_LOOP"
Name=STRING|"DB Check for record"
commatext=STRING|"0"
sql=STRING|"""SELECT [Status]"",""  FROM [TabletForms].[dbo].[MCLS015]"",""  where docref={DOCID}"""
timeout=STRING|"60"
var2=STRING|"RECORDS"
withmemo=STRING|"0"
operator=STRING|"1"
timeout=STRING|"60"
UniqueID=INTEGER|-81326141
periodicity=STRING|"0"
startdate=STRING|"43258"
time0=STRING|"0"
time1=STRING|"300000"
time10=STRING|"3000000"
time100=STRING|"30000000"
time101=STRING|"30300000"
time102=STRING|"30600000"
time103=STRING|"30900000"
time104=STRING|"31200000"
time105=STRING|"31500000"
time106=STRING|"31800000"
time107=STRING|"32100000"
time108=STRING|"32400000"
time109=STRING|"32700000"
time11=STRING|"3300000"
time110=STRING|"33000000"
time111=STRING|"33300000"
time112=STRING|"33600000"
time113=STRING|"33900000"
time114=STRING|"34200000"
time115=STRING|"34500000"
time116=STRING|"34800000"
time117=STRING|"35100000"
time118=STRING|"35400000"
time119=STRING|"35700000"
time12=STRING|"3600000"
time120=STRING|"36000000"
time121=STRING|"36300000"
time122=STRING|"36600000"
time123=STRING|"36900000"
time124=STRING|"37200000"
time125=STRING|"37500000"
time126=STRING|"37800000"
time127=STRING|"38100000"
time128=STRING|"38400000"
time129=STRING|"38700000"
time13=STRING|"3900000"
time130=STRING|"39000000"
time131=STRING|"39300000"
time132=STRING|"39600000"
time133=STRING|"39900000"
time134=STRING|"40200000"
time135=STRING|"40500000"
time136=STRING|"40800000"
time137=STRING|"41100000"
time138=STRING|"41400000"
time139=STRING|"41700000"
time14=STRING|"4200000"
time140=STRING|"42000000"
time141=STRING|"42300000"
time142=STRING|"42600000"
time143=STRING|"42900000"
time144=STRING|"43200000"
time145=STRING|"43500000"
time146=STRING|"43800000"
time147=STRING|"44100000"
time148=STRING|"44400000"
time149=STRING|"44700000"
time15=STRING|"4500000"
time150=STRING|"45000000"
time151=STRING|"45300000"
time152=STRING|"45600000"
time153=STRING|"45900000"
time154=STRING|"46200000"
time155=STRING|"46500000"
time156=STRING|"46800000"
time157=STRING|"47100000"
time158=STRING|"47400000"
time159=STRING|"47700000"
time16=STRING|"4800000"
time160=STRING|"48000000"
time161=STRING|"48300000"
time162=STRING|"48600000"
time163=STRING|"48900000"
time164=STRING|"49200000"
time165=STRING|"49500000"
time166=STRING|"49800000"
time167=STRING|"50100000"
time168=STRING|"50400000"
time169=STRING|"50700000"
time17=STRING|"5100000"
time170=STRING|"51000000"
time171=STRING|"51300000"
time172=STRING|"51600000"
time173=STRING|"51900000"
time174=STRING|"52200000"
time175=STRING|"52500000"
time176=STRING|"52800000"
time177=STRING|"53100000"
time178=STRING|"53400000"
time179=STRING|"53700000"
time18=STRING|"5400000"
time180=STRING|"54000000"
time181=STRING|"54300000"
time182=STRING|"54600000"
time183=STRING|"54900000"
time184=STRING|"55200000"
time185=STRING|"55500000"
time186=STRING|"55800000"
time187=STRING|"56100000"
time188=STRING|"56400000"
time189=STRING|"56700000"
time19=STRING|"5700000"
time190=STRING|"57000000"
time191=STRING|"57300000"
time192=STRING|"57600000"
time193=STRING|"57900000"
time194=STRING|"58200000"
time195=STRING|"58500000"
time196=STRING|"58800000"
time197=STRING|"59100000"
time198=STRING|"59400000"
time199=STRING|"59700000"
time2=STRING|"600000"
time20=STRING|"6000000"
time200=STRING|"60000000"
time201=STRING|"60300000"
time202=STRING|"60600000"
time203=STRING|"60900000"
time204=STRING|"61200000"
time205=STRING|"61500000"
time206=STRING|"61800000"
time207=STRING|"62100000"
time208=STRING|"62400000"
time209=STRING|"62700000"
time21=STRING|"6300000"
time210=STRING|"63000000"
time211=STRING|"63300000"
time212=STRING|"63600000"
time213=STRING|"63900000"
time214=STRING|"64200000"
time215=STRING|"64500000"
time216=STRING|"64800000"
time217=STRING|"65100000"
time218=STRING|"65400000"
time219=STRING|"65700000"
time22=STRING|"6600000"
time220=STRING|"66000000"
time221=STRING|"66300000"
time222=STRING|"66600000"
time223=STRING|"66900000"
time224=STRING|"67200000"
time225=STRING|"67500000"
time226=STRING|"67800000"
time227=STRING|"68100000"
time228=STRING|"68400000"
time229=STRING|"68700000"
time23=STRING|"6900000"
time230=STRING|"69000000"
time231=STRING|"69300000"
time232=STRING|"69600000"
time233=STRING|"69900000"
time234=STRING|"70200000"
time235=STRING|"70500000"
time236=STRING|"70800000"
time237=STRING|"71100000"
time238=STRING|"71400000"
time239=STRING|"71700000"
time24=STRING|"7200000"
time240=STRING|"72000000"
time241=STRING|"72300000"
time242=STRING|"72600000"
time243=STRING|"72900000"
time244=STRING|"73200000"
time245=STRING|"73500000"
time246=STRING|"73800000"
time247=STRING|"74100000"
time248=STRING|"74400000"
time249=STRING|"74700000"
time25=STRING|"7500000"
time250=STRING|"75000000"
time251=STRING|"75300000"
time252=STRING|"75600000"
time253=STRING|"75900000"
time254=STRING|"76200000"
time255=STRING|"76500000"
time256=STRING|"76800000"
time257=STRING|"77100000"
time258=STRING|"77400000"
time259=STRING|"77700000"
time26=STRING|"7800000"
time260=STRING|"78000000"
time261=STRING|"78300000"
time262=STRING|"78600000"
time263=STRING|"78900000"
time264=STRING|"79200000"
time265=STRING|"79500000"
time266=STRING|"79800000"
time267=STRING|"80100000"
time268=STRING|"80400000"
time269=STRING|"80700000"
time27=STRING|"8100000"
time270=STRING|"81000000"
time271=STRING|"81300000"
time272=STRING|"81600000"
time273=STRING|"81900000"
time274=STRING|"82200000"
time275=STRING|"82500000"
time276=STRING|"82800000"
time277=STRING|"83100000"
time278=STRING|"83400000"
time279=STRING|"83700000"
time28=STRING|"8400000"
time280=STRING|"84000000"
time281=STRING|"84300000"
time282=STRING|"84600000"
time283=STRING|"84900000"
time284=STRING|"85200000"
time285=STRING|"85500000"
time286=STRING|"85800000"
time287=STRING|"86100000"
time29=STRING|"8700000"
time3=STRING|"900000"
time30=STRING|"9000000"
time31=STRING|"9300000"
time32=STRING|"9600000"
time33=STRING|"9900000"
time34=STRING|"10200000"
time35=STRING|"10500000"
time36=STRING|"10800000"
time37=STRING|"11100000"
time38=STRING|"11400000"
time39=STRING|"11700000"
time4=STRING|"1200000"
time40=STRING|"12000000"
time41=STRING|"12300000"
time42=STRING|"12600000"
time43=STRING|"12900000"
time44=STRING|"13200000"
time45=STRING|"13500000"
time46=STRING|"13800000"
time47=STRING|"14100000"
time48=STRING|"14400000"
time49=STRING|"14700000"
time5=STRING|"1500000"
time50=STRING|"15000000"
time51=STRING|"15300000"
time52=STRING|"15600000"
time53=STRING|"15900000"
time54=STRING|"16200000"
time55=STRING|"16500000"
time56=STRING|"16800000"
time57=STRING|"17100000"
time58=STRING|"17400000"
time59=STRING|"17700000"
time6=STRING|"1800000"
time60=STRING|"18000000"
time61=STRING|"18300000"
time62=STRING|"18600000"
time63=STRING|"18900000"
time64=STRING|"19200000"
time65=STRING|"19500000"
time66=STRING|"19800000"
time67=STRING|"20100000"
time68=STRING|"20400000"
time69=STRING|"20700000"
time7=STRING|"2100000"
time70=STRING|"21000000"
time71=STRING|"21300000"
time72=STRING|"21600000"
time73=STRING|"21900000"
time74=STRING|"22200000"
time75=STRING|"22500000"
time76=STRING|"22800000"
time77=STRING|"23100000"
time78=STRING|"23400000"
time79=STRING|"23700000"
time8=STRING|"2400000"
time80=STRING|"24000000"
time81=STRING|"24300000"
time82=STRING|"24600000"
time83=STRING|"24900000"
time84=STRING|"25200000"
time85=STRING|"25500000"
time86=STRING|"25800000"
time87=STRING|"26100000"
time88=STRING|"26400000"
time89=STRING|"26700000"
time9=STRING|"2700000"
time90=STRING|"27000000"
time91=STRING|"27300000"
time92=STRING|"27600000"
time93=STRING|"27900000"
time94=STRING|"28200000"
time95=STRING|"28500000"
time96=STRING|"28800000"
time97=STRING|"29100000"
time98=STRING|"29400000"
time99=STRING|"29700000"
timecount=STRING|"288"
wakeup=STRING|"0"
deesloop
Postby Oleg » Fri Jun 08, 2018 8:27 am
You have to transform the line to standard comma-separated string if CSV file contains non-standard lines.
Use Delimit variable action to transform any string with delimiters to standard comma-separated string. Put in before step #10
The example of standard comma-separated string:
string-without-spaces,"String with spaces",another_string_without_spaces,"string with ""spaces"" and quotes"
You can use spaces in elements but you have to put it between quotes. Delimit variable action makes all necessary transformations automatically.
Postby deesloop » Fri Jun 08, 2018 11:33 am
OK, each CSV file is now a single line of text.
The equivalent of a single row in excel. No headers nothing.
It opens fine in excel and in notepad and looks to me like a CSV file should
Here's the contents of one file.
6300595,2158,Tomatin,Top compound,2018-06-04,12:32:00,John Smith,Health and Safety,,good,Audited,0,,,0,,missing ear defenders,1,,,0,,,0,,,0,,,0,,,0,,not fully fenced,1,,,0,,,0,,,0,,,0,,,0,,,0,,,0,,damaged cords,1,,,0,,,0,,,0,,,0,,all pat tested om,0,,,0,,,0,,,0,,,0,,,0,,,0,,#TobeReviewedBy#,signed,#AgentSignature#
So each field is separated by a comma and that's it.
Not sure wyy spaces are causing an issue.
Anyway I ran the delimiter on the data and it now correctly recognises the fields.
Just need to figure out the date & time fields so that the sql insert works
deesloop
Postby Oleg » Fri Jun 08, 2018 5:04 pm
Look at my example how to convert into standard comma separated string and transform date-time into your system date and time
CatID=INTEGER|1360203151
ExternalName=STRING|"Task119"
ID=INTEGER|1741476377
Name=STRING|"fix comma separated and convert date-time"
Name=STRING|"Set variable ""LINE"" with value ""6300595,2158,Tomatin,Top compound,2018-06-04,12:32:00,John Smith,Health and Safety,,good,Audited,0,,,0,,missing ear defenders,1,,,0,,,0,,,0,,,0,,,0,,not fully f..."""
varname=STRING|"LINE"
varvalue=STRING|"6300595,2158,Tomatin,Top compound,2018-06-04,12:32:00,John Smith,Health and Safety,,good,Audited,0,,,0,,missing ear defenders,1,,,0,,,0,,,0,,,0,,,0,,not fully fenced,1,,,0,,,0,,,0,,,0,,,0,,,0,,,0,,damaged cords,1,,,0,,,0,,,0,,,0,,all pat tested om,0,,,0,,,0,,,0,,,0,,,0,,,0,,#TobeReviewedBy#,signed,#AgentSignature#"
colon=STRING|"0"
comma=STRING|"1"
other=STRING|"0"
quote=STRING|"0"
semocolon=STRING|"0"
space=STRING|"0"
spaceasone=STRING|"0"
string=STRING|"{line}"
tab=STRING|"0"
variable=STRING|"line1"
Name=STRING|"Show ""{Line}"""
msg0=STRING|"{Line}"
msg1=STRING|"***************"
msg2=STRING|"{Line1}"
msgcount=STRING|"3"
Name=STRING|"Set variable ""DT_OLD"" with value ""{Line1(4)} {Line1(5)}"""
varname=STRING|"DT_OLD"
varvalue=STRING|"{Line1(4)} {Line1(5)}"
Name=STRING|"Set variable ""DT_SYSTEM"" with value ""{FormatToDateTime({dt_old},yyyy-mm-dd hh:nn:ss)}"""
varname=STRING|"DT_SYSTEM"
varvalue=STRING|"{FormatToDateTime({dt_old},yyyy-mm-dd hh:nn:ss)}"
Name=STRING|"Show ""date-time in line: {dt_old}"""
msg0=STRING|"date-time in line: {dt_old}"
msg1=STRING|"system date-time: {dt_system}"
msgcount=STRING|"2"
Return to General Discussion
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
cron
