Critical ERROR creating folders
BrianSmith
Post by BrianSmith »
I am able to reproduce this error consistantly.
I am running Windows XP Professional Service Pack 1.
I am running RoboTask 2.0.2
I right-click on the ROOT folder and select New Folder.
I give the folder a new name called "My Tasks".
I drag an existing task from the "Examples\Simple" folder into the "My Tasks" folder.
I then exit RoboTask by going to the Task menu and selecting Exit.
When I open RoboTask again the folder "My Tasks" is gone and the task that was dragged into this folder is now in the ROOT folder.
This error occurs when I create any number of folders.
All the new folders disappear after the application closes and re-opens and all the tasks that were in these folders are now in the ROOT folder.
Can you please help me work out how to keep all my folders when closing and opening RoboTask.
Thanks.
AlexeySurkis
Post by AlexeySurkis »
We fixed that bug and the new version 2.0.3 will be available shortly.
BrianSmith
I tested this and folders no longer disappear. Thanks for this fix.
