I just installed the software and I created a task and then
downloaded basic and installed it and now the task created
is gone. That is the first issue and the second is..
1. When you create a task and not sure how you know which
task is at by name in the task folder.
2. On this forum, there are lots of codes posted instead of
steps and wondering how to turn that posted code into a
task that will work in the software?
