| Quick Start Guide |
| Features |
| Getting Started in the RoboTask Window |
| Create Tasks |
| Run Tasks |
| Edit Tasks |
| Customize RoboTask |
| Purchasing |
| License Agreement |
| Trademarks and Copyrights |
| Several practical recommendations |
| Using Variables in Tasks |
| Using Variables |
| System variables |
| Custom variables |
| Local Variables |
| Create a Variable |
| Add Variables to a Task |
| Macro recorder |
| Running tasks simultaneously |
| Debugging of the task |
| Task synchronization |
| Using built-in Basic |
| Running RoboTask as an NT service |
| Installing and running |
| Using UNC names |
| Authentication parameters |
| Peculiarities of working in the system service mode |
| The visual differences between the work in ordinary application mode and in the system service mode |
| Peculiarities of work RoboTask Service in RDC mode |
| Peculiarities of work RoboTask Service under OC Vista/ Windows 7/ Windows 2008 Server |
| Errors handling |
| Menus |
| Task > New |
| Task > Edit |
| Task > Delete |
| Task > Run |
| Task > Stop |
| Task > Duplicate |
| Task > Create Shortcut on Desktop |
| Task > Exit |
| Options > View Log |
| Options > View Toolbar |
| Options > Settings |
| Options > Variables |
| Tools > Enable Automation |
| Tools > Enable All Tasks in List |
| Tools > Disable All Tasks in List |
| Help > Help Topics |
| Help > Send Bug Report |
| Help > About |
| Actions |
| General |
| Run Program/Open Document |
| Print Document |
| Send Keystrokes |
| Shift Keys State |
| Log Off |
| Pause |
| SQL Query |
| Wait for Process Finish |
| Wait for Process Start |
| Terminate Process |
| Comment |
| Dialogs |
| Show Message/Play Sound |
| Question Dialog |
| Open Dialog |
| Save Dialog |
| Browse for Folders |
| Browse for Computers |
| Input Box |
| Files and Folders |
| Copy/Move File |
| Rename File |
| Delete File |
| Write Text File |
| Search for Files |
| Change Folder |
| Create Folder |
| Rename Folder |
| Remove Folder |
| Synchronize Folders |
| Wait for file |
| SortText |
| Unique File Name |
| File Attributes |
| Zip |
| Pack Files |
| Extract Files |
| Internet |
| Check for Email |
| Send Email |
| Download Files |
| Ping Host |
| FTP |
| FTP Log On |
| FTP Log Off |
| FTP Download |
| FTP Upload |
| FTP Rename File |
| FTP Delete File |
| FTP Change Folder |
| FTP Create Folder |
| FTP Remove Folder |
| FTP PWD |
| FTP Transfer Type |
| FTP Command |
| FTP File Loop |
| FTP Syncronization |
| Dial-Up |
| Dial Up/Hang Up |
| Check connection |
| Variables |
| Create Variable |
| Set Variable |
| Remove Variable |
| Increment Variable |
| Delimited variable |
| Task Commands |
| Enable Task |
| Disable Task |
| Start Task |
| Stop Task |
| Wait for Task |
| Loops and Flows |
| File Loop |
| Text Loop |
| Dataset Loop |
| Window loop |
| Simple Loop |
| While loop |
| End Loop |
| Break |
| Continue |
| If Then |
| Else |
| End If |
| Window |
| Window Command |
| Check for Window |
| Wait for Window |
| For Windows NT |
| Start Service |
| Stop Service |
| Lock Workstation |
| Run Program as User |
| RoboTask Commands |
| Minimize RoboTask |
| Restore RoboTask |
| Exit RoboTask |
| Enable Automation |
| Disable Automation |
| Log Message |
| Clipboard |
| Cut |
| Copy |
| Paste |
| Clear Clipboard |
| Get text |
| Put Text |
| Mouse |
| Move to object |
| Click |
| Move |
| Registry |
| Add key |
| Delete Key |
| Rename Key |
| Read Value |
| Write Value |
| Delete value |
| Rename value |
| Export |
| Import |
| Network |
| Send Command |
| Send Network Message |
| Network Plugin settings |
| POP3 Open |
| POP3 Close |
| POP3 Mail Loop |
| POP3 Download Email |
| POP3 Delete Email |
| POP3 Messages Count |
| Parse Email |
| Strings |
| STR Replace |
| STR Trim |
| STR Delete |
| STR Insert |
| STR Extract |
| STR Pos |
| STR Between |
| Basic |
| Evaluate |
| Basic script |
| RoboTaskApp object |
| CD/DVD Writer |
| Write to disk |
| Erase Disk |
| Eject/Load CD Tray |
| Web Documents |
| Fill Web Form |
| Add or Edit Web Form Parameter dialog |
| Wait for Done |
| Triggering Events |
| Scheduler |
| Hot Keys |
| Tray Icon |
| Cyclic |
| File Monitor |
| Dial-Up Connection Monitor |
| Window Watcher |
| On Time Changed |
| On Battery Power is Low |
| On Spooler Changed |
| On Device Changed |
| On Palette Changed |
| On Display Changed |
| On Log Off |
| On Idle |
| Listener |
| Appendix |
| Full list of system variables |
| Other software |
