Empty Recycle bin
fneurieser
Empty Recycle bin
Post by fneurieser »
is it possible to empty the recycle bin from within robotask?
If it is, how can I perform this?
Regards
franz-georg
Re: Empty Recycle bin
RoboTask doesn't contain such action now.
Now you can delete all files from Recycle Bin folders
For Windows 7 and later it is the folder $Recycle.Bin on each logical hard drive.
C:\$Recycle.Bin
D:\$Recycle.Bin
E:\$Recycle.Bin
and so on
Use Delete File action with mask C:\$Recycle.Bin\*.*
Also turn on the Process Subfolders checkbox.
